Displays the OSPF virtual link information to ensure accuracy.
View the OSPF virtual link information:
Switch:1#show ip ospf virtual-link ================================================================================ OSPF Interface AuthKey - GlobalRouter ================================================================================ INTERFACE AUTHTYPE AUTHKEY -------------------------------------------------------------------------------- 192.0.2.11 none
Variable definitions
The following table defines parameters for the show ip ospf virtual-link command.
Variable |
Value |
{A.B.C.D} {A.B.C.D} vrf WORD<1-16> |
Specifies the area ID and the virtual interface ID. The first IP address specifies the area ID and the second specifies the virtual interface ID. |
{A.B.C.D} {A.B.C.D} vrfids WORD<0-512> |
Displays OSPF configuration for a particular VRF. Specifies a VRF by name. |
{A.B.C.D} {A.B.C.D} |
Specifies a range of VRF IDs. |
